Evan
If it's cold out, (10 F or lower) my rear Lockrite locker will often not engage when I'm just starting out in the morning. The driveline will just spin, sometimes with a faint popping noise in the rear. When this happens, I have to put it into reverse for a second, or feather the throttle to get it to engage. Then once I drive about a mile it's just fine. I'm almost sure it's due to the gear oil being so thick in the cold that it's stopping the drivers from engaging with the couplers by getting in between them. I'm running 80w90. For positive engagement you need some resistance from the shafts, so you need some natural force aside from the crosspin to push the drivers outward. That's why the little springs are in there...but I don't think they have the balls to overcome 0 F gear oil.
Does anyone else have this problem?
