- Jan 1, 2009
- So. Cal
- 2008 & 2001
Yo I was wondering if anyone has insulated there truck do to rattles, and how much did it cost?
exactly. its much easier to hunt down every rattle. if its loose wire, then some double sided tape can fix that. door panel rattling, then add some pieces of foam. the only things that rattle in my truck is whatever is in the cup holder or glove box. so i just turn up the stereo.
sound deadening pretty much just deadens the panel. stuffs great for canceling road noise. youll hear a big difference in the lower frequencies.
would some of that spray foam insulation stuff work?
nonononononononoonooooooooooo
that stuff holds moisture and will cause your truck to rust, from the inside out.
