- Sep 8, 2008
I noticed some gear oil all around the outside frame member on the left side and in a few other spots today, I can see fluid on the bottom of the diff, but it is not blowing back. Most of it is on the frame and it seems to be mostly concentrated to what appears to be a vent line. It looks like the front diff is pushing fluid up through what appears to be a vent line. Would an over filled situation cause this or something else?
I changed the fluid myself about 5 months ago, I basically filled it until the fluid started to run out of the fill hole, so if over filled it could only have been slight.
Any thoughts or ideas?
