rear brakes-wheel cylinder overtravel?
racsan
central ohio
2.5 (4 Cylinder)
the grey-t escape
ive got a very confusing problem with a van ive been working on, its a 2003 dodge minivan, have replaced the rear brakes and wheel cylinders, bled brakes and a few days later there was a massive leak inthe system, pulled apart the brakes and discovered the wheel cylinder on the passenger side had pushed the piston out of the bore fully on the side facing the front of the van. it shouldnt be possible for it to over-extend and "blow up" but it did. thought maybe there was a spring problem as one was floating around in the drum. put a new spring kit in, checked everything, re-bled brakes and put it back out on the road again. have heard the brake light is back on again and i will be looking at it again tommarrow. dont know why it could be happening, looks like all shoes are identical, no "primary" or "secondary" specific shoe. measured the wheel cylinders and all seem to be the same length. drums were not turned, just knocked the rust-ridge off with a dremel tool. how on eart could the wheel cyl expand far enough to push out a piston and lose fluid? and only on one side? it defies all logic for me. whats worse is that its not even my vehicle and i have no idea how to explain this. you would think it would have happened right away, not a few days after the fact. any ideas?
Broken spring not allowing shoes to retract/push piston back into cylinder bore.....
the drums are so oversized its allowing the piston to over extend.
If it's got the self adjusting star wheel thingys, make sure you've got it adjusted so the pads are close to the drums to start when you put it together. If the star wheel is all the way in, your cylinders will over-extend.
wrong
well im still not certian what caused the issue in the first place, we did put a new spring kit on that side after it extended apart the first time, when i looked at it again over the weekend it had not done that again, there was still fluid loss, but it wasnt from there. apparrently the line was leaking where it connects to the wheel cylinder, not nearly as bad (obviously) as when the wheel cylinder pushed a piston clear out of the bore. good to go now.
