is this going to be ok
rangerdanger9398
alden ny
i built a box for my 1996 ranger super cab i put 2 12'' Kicker Comp 07C124 subs and i have a 2500watt amp how will it sound i don't know if i should port the box. the box is 3.5 sq ft
i dont wanna sound like a jack ass but im gonna say no on soooo many levels
but it will tec work but how well and how long. is very debatable
well what is it built out of how was it put together, tell us a little about it
i built it out of 5/8 MDF and i put it together with screws and glued the inside seams
It probably can be ported. Try a 6-inch round port around 10 to 11-inches long.
Two 4-inch ports might also work, the two 4-inch ports have slightly less cross sectional area then the 6-inch, but the difference is a small one.
see i said that when you still had 1.75 CF down as your box size but you edited your post. which is one reason i said no. the other is if your really putting out 2500watts 4 ohms rms is about 1/4 of the 2500 so thats 600W rms for subs that depending on when you got them are only 150rms so your double wattage for each sub.
secondly notice how no one agreed with you when you said i was a ****ing jerk off.
how about you read some of my other post in the audio section. before you start name calling and thinking i dont know what im talking about.
it just makes you look a **** stick.
imma back 4x4 up on this one he really does know most of his stuff that ive seen. and im sorry but ive never seen kicker subs hold that much power unless they were L7s for a very long time. what kind of amp do you have?? most amps are over rated unless its a better brand. so its possiable that your 2500 is only like 2000 and that makes it a little better.
thank you little, but i did some back logging and this is the guy that got flamed for being raciest on another post. so i really dont care what he thinks of me...... i cant help them all. but ill try
not a prob 4x4.
and to answer your question about the box, what are the dimensions of the box?? and how do the subs face in the truck??
I prefer sealed boxes with a little more air space than required but that just my preference.
I back 4x4 for several reasons
A) 2500 watts is a ridiculous number, my guess is he means peak power so that number doesnt mean anything to me
B) The brand Kicker... I hate kicker... garbage
C) 4x4 has agreed with me before on audio
If your trying to compete with me then yes it is a ridiculous number. You better increase that 4 or 5 times.
congrats its a van thats too loud to listen too...... If we're competing though I have an 18" acoupower woofer that makes a bridged crown xti 4000 amp clip. Those types of vans are usually pretty sick to check out at car competitions though but I don't consider them to be car audio anymore. More along the lines of how many battery amp combos can we fit in this van.
