welded d35 durability
how long before the d35 fails
  • 3-5 trips and a hub fails
    Votes: 0 0.0%
  • broken carrier 1st trip out or any time after
    Votes: 0 0.0%
  • broken welds on the spiders ( quality welder is doing it)
    Votes: 0 0.0%
  • strip the slip joints splines at any point
    Votes: 0 0.0%
  • Total voters
    20
  • Poll closed .
Well, if you're trying to break the thing, I would say 1st time out. Anything can be broken if you beat on it enough :rolleyes:
sounds good. 17s it is then. i will be ordering 17s for the b2 then if i get tires before the 60 put in.
thanks guys.
86
15-17 means alot less sidewall and airing down wont be as beneficial.
i dont pass on a challenge.....
well, unless it already made me poop my pants, then i take the bypass......
86
A guy was wheelin near Pipeline, WI this summer and blew out a set of Rockwell 2.5s turning only 38s.
i want to be that guy. well, unless it was his mechanical error that caused the failure of the rockwells.
86
86
We get the idea already. You're the most hardcore person on this website, and possibly the entire internet.
:nopityA:
:nopityA:
:thefinger:
i just enjoy a good dent or 2. i doubt a guy on 33s wins the hardcore award. maybe the stupidity award once in a while. it would be a hard time breaking rockwells.
86
I took some pretty damn gnarley hill climbs and obsticles when my truck was stock IFS on 35x15.5s, Chuck. Even with only 4.10 gears and a 3.0. I haven't broken a damn thing. Including the tranny.
Don't you know man? It's all about technical wheeling with smaller meats now.
Good lines and the right mixture of brains and balls will get you, or anyone further then fuckin one tons.
adam i agree. we will see, the d35 mite still have a long life under the b2 ahead of it. but i will be welding it and i will be putting 36s or 37s on the b2 with a 4liter at some point when the cash comes available.
running locked (or in my case welded) is a entirely different situation than running open. you will know soon enough.
86
Is anyone in here using Aussie locker or Powertrax locker for the front diff? If so how does it perform when in 2wd when turning?
I have HEARD from others they work just fine. not to mention if you have a 97 or prior ranger you have/ can install manual hubs and the front axle will be completely disconnected from the tires in 2wd. so there wont be any reason for the aussie to make noises.
86
It's a 99 with the vacuum hubs removed using Explorer hubs.
