- Oct 21, 2008
- Ontario Canada
how long a clutch lasts is entirely up to the driver. its not uncommon for semis to have upward of a half of a million miles on an original clutch, and a million miles or more on the transmission.
of coarse there are always examples of weak manuals and strong autos, but we cant deal with them from here on an individual basis. we can only look at them as a whole. and on the whole, manual transmissions are more reliable.
Funny you say that see i said ealier i am a Licensed Diesel Truck mechanic (AKA i fix Semis for a living).
And in Semis i have seen clutches and trans last past 1,000,000 kilometers with a good driver. BUT a Semi is NOT driving in stop and go traffic 100% of the time and most of its time is spent on the motorways were the clutch is not used. I drive truck myself as part of my job and the clutch on a rig is used ONLY for starting and stopping (unless your new LOL).
BUT in a transit application a clutch would not last NEARLY as long simply due to the heat factor. Regardless EVEN the BEST driver is gona slip the clutch a bit on take off its simple physics and that creates heat. And when done over and over in a stop and go condition. that heat builds fast shortening the life of the clutch.
With the Auto it is designed to withstand heat as the only true mating from engine to drive line is OIL and that oil is MUCH easier to keep cool. ON top of that that oil is replaced at regular intervals to prevent breakdown of the oil from said Heat. I used to run the dyno for a company that rebuilds autos for transit buses. And on top of that i was the guy tearing em all apart and inspecting em. And in that application it was not uncommon to see buses running with 900,000kilometers with nothing but oil and filters.
As for autos in general being weaker than standards i beg to differ. Most of chevys TH series were bullet proof as was Fords C6 and i even personally owned a Dodge Van with a 727 auto with 450,000kms on the original drive train and it was used to pull a 20' fishing boat all its life.
I even had a 1996 Ranger 3.0L V6 auto 4x4 that seen 260,000kms on the stock trans even with me using it as tow rig towing up to 5000lbs. I sold it so i dont know when that trans failed of if it ever did. And we all know that things trans reputation.
Fact of the matter is i think a lot of Auto failures stem more to lack of maintenace than any true weakness.
