my broncoII 2.9L fuel injected is having some issues. here are the symptoms.
when first started it will have an irratic idle, 500 rpm to 1500 rpm, about 5 min after it will smooth out
idle will very anywhere from 900 rpm to 1400 rpm, doesnt seem to have any sort of pattern, but it favors the higher rpm most of the time
when driving at a constant speed with the rpm between 1500 and 2100 rpm the engine will studder and jerk the truck, when reving engine in nutrel, engine seems to run ok for the full range of rpm's.
throtle set screw is all the way back, ive replaced the cylinder heads, the spark plugs, the coil, the fuel pressor regulator/diaphram, air filter.
i cant figure it out.
thanks guys
thanks guys
