The 88 Town Car 5.0 has a roller cam (but the smallest of the production 5.0 cams) rated at 150 hp. Heads are the E6SE's, flat topped pistons with no valve reliefs. Intake is similar to the H.O intake but with a different upper (looks the same but they used a different engineering number, so there's something diffferent internally) The block, crank, rods, and roller cam hardware are the same stuff used in the HO motor. You can improve the motor's HP output by simply swapping in any of the other production roller cams, even up to an E cam. If you swap heads and cam, you'll then run into piston to valve clearance issues. The valves are deeper into the E6 heads than all other SBF heads, hence the reason the pistons didn't have valve reliefs.
