31x10.50r15
o4rhm1
Wichita falls
im shur this question has been asked many of times but, will 31's fit on a stock ranger/bronco II, the wheels are close to factory, dont know the back spacing or anything on em..... Any help will be appericated
Thanks
Ian
i got 31/10.5r15 mud terrains on my stock 93 4x4 ranger. works fine with no rubbing. but it does cut it close and rubbs a little in the trails. so i guess it all depends on the height of your bronco. i can post a few pics if you wanna see the clearance
i have had several 1st gens. some rubbed and some didn't i even had a 1st gen with 32x12.50x15 that didn't rub but it had been cut
Thanks Guys, KOA if you dont mind please post a couple i would like to see what you have.. Thanks for the help
31.10.5 on 8inch rims stock back spacing. some cutting necessary maybe 2inches of lift, and that would be pushing it.
31x10.50r15
sorry im so late on a reply. ill go outside and snap a couple photos right now. be back in a few
i had 31s on my 86 ranger 4x4 and they worked fine, but mudding they would sometimes rub
I'm shur this question has been asked many of times but, will 31's fit on a stock ranger/bronco II, the wheels are close to factory, dont know the back spacing or anything on em..... Any help will be appreciated
Thanks
Ian
says his b2 is a 87 in his sig. bit of difference to a 93
ya i know, but i was just giving a reference point. granted the b2 rear end will be much lower
Sorry its been a while but with work and a b2 to work on its kinda eating up my time!!! Ok thanks guys, im starting to think that a 2 or 3" body lift for now.....i really didn't want to but i guess i just spend the money and do it, and as far as the tires. I will go ahead and get the 31's i think it will look good and hopefully shouldn't rub
