- Apr 10, 2008
- Age
- 41
Background
88 Ranger, 2.9 5 speed. Fresh late model heads, no cat, recent high pressure fuel pump. About a month ago it started missing every once in a while like someone briefely pulled the coil wire and stuck it right back on. This went on for about a month until last weekend , i started it up one morning and it ran like it was only hitting on 5 cylinders. Every morning since then it will run like its missing a cylinder for about 5-10 min and then it will run fine (except with the previously mentioned miss). Every once in a while after its hot, it will feel like its dropped a cylinder again. When it runs good, it runs GOOD.
What i've done so far
Pulled codes (Using KOEO method with test light)
-67- i bypassed the neutral safety so no concern
-95- the fuel pump is on a toggle and has been forever, so no concern there
-29- i think this is the problem, but not sure since mine has no egr
-14- ignition pickup irratic- this is what i had originally thought, but it only threw a 14 once and im not sure i even read it right. I cleared codes, took it for a long drive, and it did not throw a 14 the second time.
Replaced Ignition Control Module (TFI)- no change
Replaced cap and rotor - no change
Plugs all look perfect (light brown)
Double checked/cleaned up all grounds
I'm going to put a fuel filter in it tonight, but doubt thats the problem.
My thinking is that it is something to do with the pickup inside the distributor. Any advice would be appreciated. Thanks
