- Oct 22, 2008
- WESTMINSTER CA
the 4.6 and 5.4 have had problems blowing plugs out of the heads.. did ford ever make changes to the heads to prevent this??
never had a problem with either of my 4.6s. user error is a big cause of it. when you change the plugs make sure there cold and dont use antisieze which acts as a lube and makes it easy to overtighten and strip out, if you change em cold and dry youll be fine
In 2004 they completely redesigned the 5.4 cylinder heads to make them have 3 valves
ya, now your lucky if you can get the spark plugs out when you want to...the 3 valve is a shit design.
Well most of the plug will come out for sure, but maybe not all of it.
you guys must have some kind of miracle gas there. its been my experience that they break off more often than not.
i worked at the local dealership for over a year...all the other techs and myself were breaking them left and right.
