- Dec 17, 2008
has anyone ever put a dana 30 from a cherokee or wrangler in the front of a ranger to get rid of the ttb front.Its still coil spring and on the same side?
Just going to through my 2 cents in but if your going to go through the hassel of putting a Dana 30 under your truck why not just go straight to D44 its going to be just as much work and its already stronger to begin with. You can always upgrade it even more but thats just my opion. why do that much work to put a D30 under when u can go D44 and be stronger to begin with
i know you can really beef up a d30.Ive had a coulpe of them that survived 35 or 37 inch tires.Im normally a jeep guy but got my 94 ranger cheap thats why i bought it.Any help would be great on a swap.Does he coil buckets need to be moved and such as that.Any links or write ups would be great.Thanx
the problem im having with it is i HATE the way it sits going down the road.I can never get the alignment rite and when it does it doesnt stay.I only got a 4" lift with 32s.I got a d30 sitting in my yard and figured it would be easier.
Lastly, the D30's cartridge-bearing design is inferior to the D35's serviceable wheel bearing setup with locking hubs.
And then you lose the 5 on 4.5 bolt pattern too, which defeats the purpose of using the D30.I believe you can convert to D44-based outers, but the cost of the conversion kit is SCARY.
