justin99
- Dec 17, 2008
I have a 99 3.0L. I was changing the oil one day last week and messed up pretty bad. I was having trouble screwing on the oil filter from the top of the truck (i just couldn't get it lined up right) so i decided to try from the bottom. I got the oil filter on from the bottom but didnt have much room to move my hands so i just ran it on the threads some and decided i would finish tightening it from the top. I was already under the truck so i went ahead and put the drain plug back in and got everything out from under the truck. I completely forgot to tighten the oil filter and started it up. I backed out of the driveway and took off down the road. I drove about 2 miles before the truck shut off while i was sitting at a stop light. The truck wasn't sluggish, didnt have a loss of power, and never gave me any knocking noises. I opened the hood and realized what i had done. I put oil in it and the truck wouldnt start. When i turn the key to start it, it was giving me one click and then nothing. The next day I tried it and same thing. After trying to start it a few times, it started kind of turning over. It sounded like it made about a stroke and a half and then it wouldnt do anything. I pulled the plugs and sprayed some tri-flow in all the cylinders. I also tapped on the starter with a hammer a few times. I tried to start it again and it slowly started turning over. It turned over a few times and stopped. Now when i try it just gives me one click and nothing happens. Do you think the motor is fried? Or do you just think its the starter because it got soaked in oil? Any advice would be helpful. Thanks
