I am going to be replacing some parts on my D35(truck is a 1996 Ext. Cab 4.0L 4x4, warn manual locking hubs if that helps) I have been doing a lot of looking around in the tech library and the forums but I cant seem to find a straight answer
I wanted to know how many of each part i need to rebuild both sides part numbers?? (trying to stick with Spicer for as many of the parts as i can)
1) Ball joints? 2 upper & 2 lower?....spicer a good brand for these?
2) U-Joints? will be upgrading to spicer 5-760X but dont know how many to get
3) 4 Wheel bearings, 2 inner & 2 outer? who makes good ones? part #?
4) anything else i should look to replace while I am down there?
5) I only have your basic set of tools. i know i need a ball joint press, what do you recommend? do i need a tool for the wheel bearing removal & installation?
Sorry to ask so many questions i just want to make sure that i get all the right parts and the correct number of them. Once i start this project i wont have a vehicle so i want to get this done as fast/correctly as possible. Thanks in advance!
