- Aug 26, 2008
- mt holly nj
I Have A 91 F150 4x4 302 5 Speed How Hard Will It Be To Put In 87 Ranger 4x4 With 2.9 5 Speed I Have The Whole F150
with the 91 harness your basically gonna have to wire from the 4-plugs on the engine harness to the ECU, being the rest is intigrated into the body harness of the f-150. you still need to swap oil pans to the mustang, and if you want the hood to close you need a body lift, as for the air box toss the 91 box out and get a 85-86 air box(alot smalller), and with the exploder 4.0 rad you looking at about .5 to 1inch in clearance to the radiator if you don"t tuck it(the tranny cooling lines where damn near touching my power steering box so i tucked the radiator). personally i got fed of with trying to make the f150 system work so basically im going carb
