- Aug 30, 2007
- Age
- 38
- Cass Co, Missouri
did you run a pipe UNDER the axle?
Yeah... I figured it would make a nice skid plate...
so do you think maybe now that there was a reason for the spring loaded ballsocket at the rear of the cat?No flex pipes, as of now, it's fully welded from the y-pipe flange all the way back.
you're saying your factory cat had a flange joint on the rear? i bet it was cut off for that oversized setupOh yeah, only thing is... My truck never had one.
too many hangers so the exhaust won't move with the engine torque/frame flex.
thats a possibility. how many hangers did your system have UrbanRedneckKid?
ive got 3. one just behind each tip, and one right under the rear of the cab (right after my glasspacks) holding up both pipes.
