Pic Request: 35s no lift
I dont care what you guys say as long as we get some more pics up.
you must not wheel hardcore guys much.
86
what, a bunch of guys with 4"s of wheel travel and cobbled together pieces of crap. No, i dont wheel with them cause they always break something and i have to pull them out.
uhh.. i have 33's on mine that isnt lifted.. not sure how you could squeeze 35s on it without trimming a ton
A true prerunner isnt lifted.
hmmm, well im pretty sure you cant get 20" of travel out of the front end while keepin the factory height unless you got a CORR truck and those are full tube chassis. True prerunners are lifted, its all on how the suspension is tuned. even drop bracket lifts still can serve in a prerunner, ask Raceranger97. he has them and romps the hell out of his truck. anyhow if you would like you could probably understand what im sayin more in the prerunner section and even put this type of discussion there
Back to the topic here is my buds Gen2 BII on 33s. it will easily clear 35s and still able to flex and wheel the crap out of it. jus gotta get eh tubs made
its only got 4 inchs of travel...... right........ mite want to read up before you go spouting off at the mouth.
sitting on the ground level
full droop.
i have another 3-4 inches of stuff that isent 5-6 inches due to shock issues.
86
full droop.
86
well that suspension doesnt look to STOCK to me, it looks like you have extended radius arms and a little lift there.
roughly 2.5 inches of lift and 33s. just because it appears to be "cobbled together" does not mean its a huge pile of parts. most of the guys i wheel with run things that appear to be "cobbled together". kiss enough trees and run enough trails that challenge your rig and yours will look the same.
86
I never said that your truck was a cobbled together piece. it looks like a like a good little wheelin b2. I was just saying that running 35's with cut fenders and no lift is wack ive got around 7.5"s of lift, 35's, and cut fenders and i still rub at full lock and not even full stuff
A friend of mine has a stock ranger with 35s and chopped fenders with no interference at all.
i am not poking you in particular. many folks are under some kind of crazy impression that whacking the fenders welding the diffs and wheeling is a bad thing. if i had a trailer mine would be even more whacked together than it already is. look in the "pimp my POS" thread. you will get a good laugh at my pile of crap wheeling toy. as far as rubbing, i only rub my radius arms and i am in the process of fixing that. i will soon be running 35s or 36s with 2.5-3 inches of lift. cash and lack of a 4liter is holding me up.
86
