into the vehicle main wiring harness and eventually to the PCM...
what are you trying to accomplish?
that big box on your firewall with all those wires coming out of ithaha. you didn't answer wicks question tho.
you can tap into the VSS wire anywhere along its length. my manual only goes back to '91, but it says the signal wire is the grey wire with black stripe. the pink wire with an orange stripe is ground. if all else fails you can probe the wires with a DVOM to see which one is ground.
they must have changed the colors on gen2 trucks then. youll have to get a test light or DVOM on the case. the wire you want is the one that isnt grounded.
Cool man, let us know how it goes. BTW looks like orange/yellow is ground. good luck.![]()
that doesn't matter though i got enough lights in the cab now to spot a deer 1000 yards away well maybe not that far but going from 1 winkydinky dome light to 3 lights in the rear and then the ones in the ohc oh and lighted visors its nice.
