will this lift kit fit?
It will fit on a 2wd BII because the engine cross members are the same, however it will not work on a 2wd Bronco II as the passenger side beam is longer than a 4wd Bronco II.
prepare for another bashing, you just said it will work on a bII but won't work on a bronco II, so i'm assuming you meant ranger.
