Junk Collector
⭐Supporting Member
Truck of Month
I am going to be starting my SAS sometime soon when I get the cash to buy gears and stuff. I will be using an EB D44 and a 31 spline 8.8 out of an explorer, because it's already set up with disc brakes.
First off, how do the widths of these two compare? This leads to my next question...
Obviously I want to keep the same bolt pattern all the way around. I am thinking of using wheel adapters, but I want to use them on the narrower axle so that both end up being around the same width. I am also not above getting one set of shafts redrilled to match if they're pretty close to the same width.
I am not sure where to go with this. I also have the option of going with a 9" EB width rear, but it doesn't have disc brakes...hence my conundrum.
I'm sure this has been done before. What do you guys think would be my best option here?
