what do I need for 31's?
jarfly
How much of a lift do I need for 31's? Dont say cut the body cause my body is in to good of condiction to cut.
PA 3inch body lift will do it.
I've got 31x10.50 on my Bll. No lift, no cutting.
I am running 6" of lift on my '86 BII to clear 31" tires. I actually rub the rear at no where near full flex in the rear and the front rubs some when flexing and turning in the front.
2" rough country leveling coils and 3" blocks in the back to fix the sagging leafs. put 31x 10.5's on stock 15 x7 rim. pics up at cardomain.com just search for b2redneck. i've got other posts on this site of mods; just do a search for, again, b2redneck
It really depends on what kind of lift you get. If you get a cheaper stiffer lift, you won'y have as much flex and won't rub as much (or at all). Or like mjones said, you can run 6" of flexy suspension lift and still rub. I have 6" on my truck as well, and rub on all 4 corners pretty bad. And I was planning to run 33s like this...
I've run 31's on a stock BII.
Really depends on the wheels you have, and how much your springs are sagging.
I have 34-10.5 15 with 4" rough country and 3 in pa body and get very little rub with offset wheels . I didn,t cut a thing on mine. It flexs like crazy. I had 31's on it while stock and had no trouble at all with stock wheels.
31s stock ,no lift ,no rub ,no problem .Save your money for something else.
I can attest that you are NOT correct. An '87 will not fit 31's without rubbing. I couldn't get the 31's to clear on my '86 without rubbing.
Possible height diff on 84/85 and later? They worked fine on 84 b2.
