- Nov 1, 2008
I recently bought a 92 ford ranger xlt. It has the 2.3l engine and 5 speed manual trans. I was changing the trans fluid and I found what looked to be gear lube. I looked on here and found that this trans takes atf. My question is if I just fill the trans with atf will the trans be ok? Or should I fill the trans with atf, drive it for a little bit, then drain and fill with new atf?(some people tell me atf is like a detergent and can clean out most of the gear lube without disassembling trans)
