Need a parts list.
koda6966
The green part of NY.
Hey all.
I need a parts list for what I would need to do a 5.0 swap on a 93 Ranger. Any ideas where I would find this or know what I would need
So far the info I have says I need the following.
Battery cables.
Radiator and hoses. Could I use a 4.0 Rad & fan?
Motor mounts.
Fan and shroud. Does it have to be from the same vehicle as the engine?
Manifolds and Cats.
Fuel pressure regulator.
Throttle cable.
Also, a T5 swap from an A4LD would follow. Need the same for that.
Any help appreciated.
carb or efi?
IMO, get a donor car with everything you want. One place quoted me $1,200 for a just a used 5.0L HO engine and T5 trans. You can get a donor car for that much, which will have most of what you need to make this work. A lot of that stuff on list is sort of trivial, like the battery cables and hoses. There's nothing specific to that, there's a million ways of doing it. See Wade's posts for info on motor mounts.
Pete
Anyone know where I can find a parts list for a M50D swap from A4LD on a '93 2wd 3.0 Supercab?
