- Aug 15, 2007
- Age
- 35
136 (R) Oxygen sensor not switching/system lean Left or Front HO2S - Fuel control
I get this code when the engine is running. I know I have a small exhaust leak where the exhaust port meets the manifold, however my truck shouldn't run rough until the O2 sensor warms up. The computer doesn't go into closed loop until the coolant temperature sensor tells the PCM the engine is warm. I believe they are heated as there are four wires going to them. Unless the warm up period is very short. I cleaned the MAF very well, TPS seems to be functional unless something else is wrong inside, and no vacuum leaks. Plugs, wires, all good. Possibly fuel pressure test I'll just have to get a testing kit. However this code seems so appropriate to my situation as there is an exhaust leak on left bank which would cause a false lean condition. Any help please.
