- Oct 27, 2007
- Fort Wayne, IN
I need coil springs for a 4"lift, I want a softer ride than the superlift ones i have. What are some good ones? How about jeep coils?
they don't like a lot of weight,his 4 banger truck should be fine.The duff coils sag out way to quickly.
no,the two coils are the same unsprung height (about 17") but the duffs give more than an inch less lift making them flexier. call skyjacker,you'll find out those coils are 480ppi,the 6"ers are 435ppiSkyjackers and Duff's are almost exactly the same as far as spring rate. The Skyjackers are right at 400PPI.
from here- http://www.therangerstation.com/forums/showthread.php?t=8788. this is the 2nd set of 4" lift coils(skyjacker) i have had and both times i have ended up with 5-6" of lift![]()
I need coil springs for a 4"lift, I want a softer ride than the superlift ones i have?
with or without a winch and higher offset wheels?heavier third gen truck?that will account for the 1.5" sag.there have been more than one first and second gen trucks with way too much lift out of the skyjacker 4"ers.plus the high ppi rating=My SJ 4"ers only yielded 3" lift for me
the 2.5"ers or the 3"ers? i'm really interested what the new 5.5" duff's settle out to.i'm not a huge fan of the 6" jackers,been there done that.On my V6 ext. cab, I ran used Duff 3" coils and F-150 spacers for a while.
The bad thing is, Duff wont sell their RBV springs separate from a kit. When I called last week to see what their PPI was, they said they don't give that information out because the RBV is the only spring they don't sell without buying a kit.i'm really interested what the new 5.5" duff's settle out to.i'm not a huge fan of the 6" jackers,been there done that.
there are ways around it.like having me or somebody else who has a kit buy them for you.once you have their stuff(the base kit) you can swap parts ,get replacements and upgrade as much as you wantThe bad thing is, Duff wont sell their RBV springs separate from a kit. When I called last week to see what their PPI was, they said they don't give that information out because the RBV is the only spring they don't sell without buying a kit.
