Towing question
liner80
10+ Year Member
Hello all I am new to the forum. I have a 01 ranger supercab 4x4 with a 4.0 auto trans, and 4.10(I think). My question is this winter I am going to be moving and will be pulling my enclosed trailer 6x12 (1300lb empty). I will have it loaded with around 2000lb of stuff. I have to go about 900 miles so my question is can I use OD or only pull it it 4th. I hate to pull in 4th for that far and run the motor at that rpm for that long. Will it be alright to pull in OD?
IF so should I installa bigger trans cooler? If yes can someone point me to a good one? Thanks for the help.
Josh
try it in OD. If the trans is shifting searching for a gear all the time, the shut OD off. 3000# you should be fine as you are.
i would stay out of overdrive regardless. spinning a few extra RPM isnt going to hurt the motor, and as a result you will run cooler, get better mileage, and have more power available.
i always reccomend using an auxilery cooler when towing...but if this is a one-time thing and you dont want to spend the extra money, added wear on your trans. will be minimal.
welcome to TRS!
I never use OD when towing. I do have a manual transmission but that does not change the engine rpm in high, direct drive gear (non-OD) compared to an automatic. I typically run about 3,500 rpm on the Interstates. Most of the time I tow a combined weight of around 3500 lbs with about 800 lbs additional on the bed. My longest tow has been 5,000 miles round trip. With over 90,000 miles on the engine now, I see no ill effects from towing out of OD.
If you don't want to run the engine at the higher rpm, you can always slow down.
i tow 4 full sized atvs from s. fla to okeechobee and never engauge it into overdrive, but i also got 3.0 with 3.73 gears on 33x12.5, but fuel is a small price to pay for wear and tear on the drive components
If its not working the engine and shifting back and fourth then obviously the vehicle doesnt know anything is back there and running O/D is no different then running it with an empty truck.
Now if its constantly shifting back and fourth, and losing speed when it shifts, shift into 3rd.
later,
Dustin
