will 33s fit with a 2in lift and 3in body
91rangerstx
Michigan
The short answer is yes.
Hell you could probably 34's with the right backspacing.
33s will fit with just a 3inch body lift
wrong. 98 and up they will but not on the older ones unless you want to do some moderate trimming.i am currently running around a 3 inch suspension lift and have cut large amounts of fender to make my 33s fit. 2 inch coil spacers will more than likely throw your alignment (camber) out of spec. potentially to the point it cant be aligned.
86
your truck has a factory 2" lift.it depends on if you want a 9" lifted pile and no trimming or somewhere imbetween.you need to look at more peoples trucks to decide
It will clear them on the streets but once you go wheeling you will rub alot.
you can but you will need to trim a lot i got a 3in body and 2 in susp and i rub my 31 with no triming but yes it can be done
I'm running 31.5's with just a 2" susp lift. I get very slight rubbing at full lock, either left or right it rubs the sway bar. No rubbing at all vertically, just on steering.
Ran into a guy last night who is running 33's with just the 2" susp lift, the body lift would gain the clearance neede vertically but you'll need to space the wheels out somewhat-probably 1" or maybe 1 1/2" by using wheel spacers or getting rims with less backset.
But I can only speak for trucks that are 07/08.
