2.9 trans
ranger
Pittsburgh,Pa
i wanted to know if you could change the gear ratios in the trans or if you have to get a different trans and if so what trans would fit that has a lower ratio
No, no and none. Can swap in a 5 speed manual.
i have a 5 speed manual in it already it came from the factory that way
ya but the main problem is that the trans is geared to high
Umm, just how does your vehicle distinguish between gearing in the transmission and gearing in the differentials or transfer case?
well if the trans had a creeper gear it would make it easier all together then i wouldnt have to worry about changing both diffs btw i know this is the wrong thread but how hard is it to change gears in the front diff
