For what you can tow with that truck I wouldn't waste the time or money
I was really looking for some intelligent people who might know some manufacturers. But thanks anyway.
whatever that truck can safely handle, the stock rad will be FINE.
+1, Ford did test these things at the factory. If you are having problems keeping the thing cool you need to get it fixed because something is wrong with it... or you are abusing it.
I have worked the snot out of my little 23 year old single row radiator in my Ranger, even with an auto it has YET to get hot.
Im the dummy?? I have a 4.0. Go get a truck with some balls. Intelligent people don't buy a 4 banger for towing. Buy a BIGGER truck. All I was saying was that for whatever that truck can safely handle, the stock rad will be FINE.
Really? You know this for a fact that Ford tested the Ranger cooling system by towing loads around in the desert mountains?
Ya, right.
Volvo Arizona Proving Ground (VAPG) - Wittmann, Arizona
Volvo Arizona Proving Ground opened in 1985. The Proving Grounds consists of 1,498 acres (6.06 km²) located one hour northwest of the Phoenix Sky Harbor Airport at an elevation of 1,650 feet (500 m). Volvo Arizona Proving Ground is operated year round. The climate is of a desert type with low annual rainfall and low relative humidity. Daytime temperatures are high throughout the summer months. The winters are mild. Nighttime temperatures frequently drop below freezing during the three coldest months, but the afternoons are usually sunny and warm
Well you've not towed much.
I used to tow a 3500lb trailer with a 1969 Toyota Landcruiser that had 135hp. It had a 4" thick radiator that must've held 3 gallons by itself. I towed all over Montana in the summer. Sometimes doing a whopping 20mph up a pass. I'm saying this because some of you weren't born when 143hp was a lot of power.
http://en.wikipedia.org/wiki/Ford_P...oving_Ground_.28VAPG.29_-_Wittmann.2C_Arizona
Dunno why they call it Volvo now, in my '85 Ranger brochure they just call it the "Arizona Proving Grounds"
They put them thru the paces doing what they are rated to do so they avoid unneccesary warentee claims and bad publicity.
