2010 e fan compatibility
PetroleumJunkie412
Unofficially Missing
⭐Supporting Member
Dirtman's Basement
PA - USA
Let's see Paul Allen's Ranger.
Tooling around on rock auto, and saw this...
Apparently the 2010/11 2.3l rangers came factory with an electric fan.
Anyone know if the fan and shroud are bolt in for the 4.0l? I don't see why they wouldn't be, but ford does stuff all the time where they'd be incompatible
You know, I saw some of those in a junkyard and didn’t know what to make of it. I didn’t really want to pay for one only to find it wouldn’t work for one reason or another and at the time I didn’t have time to try fitting one in an older Ranger in the yard.
Is that the one that was supposed to be on the front of the radiator for "additional cooling"?
No idea. Never looked over a duratec truck.
the 2.3s come with a small electric fan, my 2005 has one.
they also have the regular engine driven fan.
My '08 2.3 has the engine-driven fan.
Interesting. Any chance I can get photos of the small e fan? 😁
The 2008 Ranger that I used to have had the 2.3l with both the belt driven fan and the electric fan and the electric fan would come on when I would turn the A/C on or the defrost.
I'm pretty sure someone here runs with just that efan....
Maybe it's @stmitch
Maybe it's @stmitch
Well. I used to run with a 3 e fan combo with the 1988... worked entirely too well. The front Mercedes pushers would windmill and overcool at highway speeds, and the main big one would only kick on in traffic.
With the new vented hood, I doubt I'll need anything as big as the mechanical. Considering putting to two small ones on the intercooler and one big one as backup like I did with the 1988. Was hoping there was an "Easy button" drop in.
I'll get back to you on that easy button.
...if I find it.
That's wild. Was yours an auto?
Yeah, I think all of the Duratec trucks had a factory efan. Or at least all of them with AC.
I run a thicker radiator than stock. Pretty sure it was from a 5.0 Explorer, but the core is twice as thick as stock, so it's the same depth as the side tanks instead of half the thickness. The radiator dropped right in, and the Duratec efan shroud bolted on with only some minor trimming.
- I trimmed the top of the shroud to fit the thicker radiator core
- I trimmed the rear of the shroud to avoid contact with the serpentine belt and accessories
- I removed a molded in mounting bracket near the top that interfered with my air intake piping and wasn't needed.
The fan is just controlled with an adjustable aftermarket fan controller so I can set the trigger temp.
I have a very large after market efan and no fan shroud at all. It cools so much better than the mechanical fan. The shroud doesn't seem to be needed.
I've seen a lot of commentary for.both. I'm trying to Engineer heat issues away before this moddbox kit gets bolted on. Cooling is one of them. So far, I may stick with the mechanical to avoid complexity. Vented hood is supposed to be here in August, and im thinking that may be enough, but no way to know until it happens.
