No Rear Brakes
johnnybronco
Austin, TX
'89 B2. Rear brakes shoes are not moving. Pulled the bleeder valve and got about a spoonful of fluid after pumping the brake pedal 50 times. Replaced shoes about 3 or 4 years ago. They were working then. Master cylinder is only 3 years old. I'm thinking brake lines are clogged due to old fluid/never had a complete flush/age? Anybody have other ideas? I've never looked at brake lines before, but then I've never had a 37 year-old vehicle before.
My rear brakes weren't getting any fluid at the wheel cylinders.
It ended up being a clogged Rear Anti-Lock Brake System (RABS) solenoid (along the drivers side frame rail).
I removed the solenoid, but kept the electrical part...otherwise you will have a constant warning light.
HTH
HTH
Thanks, I'll give that a shot. My rear antilock light has been on for ever
