92 Explorer 4x4 drivetrain into 88 Bronco 2
Harleton
TX - USA
Vehicle
Ford Bronco II
Drive
So much info on here very easy to get lost. I’ve got an 88 Bronco 2 2wd & manual trans. Would the front and rear ends off of a 92 Explorer fit under my B2? Read lots of info on rear end swap but could find anything on transfer case, front axles etc. Wanting to upgrade to a 4.0 engine which Explorer has. Explorer also has automatic transmission which I would like also. Thanks for any advice / info
Conveniently yes you can use the complete engine/transmission/transfer case/front axle from a '91-94 Explorer, might need to move the transmission crossmember but the holes should be there. Obviously the front driveline should work but depending on which transmission you have (should be an FM146 I believe) I "think" the rear driveline should be the right length but someone else will need to chime in...
As for the rear axle if you've looked into it you probably know you'll need to add spring perches and shock mounts and swap to the U joint flange from the Explorer driveline. Parking brake cable will need some tweaking too.
@Joneskvn
🌿🎉🎉 CONGRATULATIONS!! 🎉🎉🌿
If both chassis (88 BII and 92 Exp) were 4 wheel drive, then the engine, transmission, transfer case, front drive line from D35 (axle) and rear 8.8" (axle, moving the spring perched to top of tube and shocks mounts) including front and rear complete suspensions are bolt on. The rear drive line from the Explorer must be shortened to work, that is what I did.
You will need the complete interior and engine bay wire harnesses, the PCM, the BII RABS can be used or install the Explorer's complete antilock brake system (I kept the BII RABS). The wiring for the lights is the final decision, I repurposed the BII's but recommend using the complete Explorer light wire harness (engine bay, interior and rear + all external lighting) too, for simplicity.
Of the auxillary components, most are reusable BUT all BII pulleys are "V" and it uses 3 belts while the 4.0l uses a serpentine which is grooved
• the brake master cylinder require different size line fittings
• the power steering pumps use completely different line fittings
• the 4.0 intake ducting and air box are different
• I chose to use the entire Explorer heating/AC/ducting, bolted right on
Please consider carefully your options in the cab, there are 2 distinct paths:
1) keep the original dash/column/AC/ducting and demonstrate your electrical expertise
2) incorporate the Explorer dash/column/heater/AC/ducting and controls...demonstrating your sheet metal and fabrication skill
I chose #2 as I needed to repair firewall, wiring and dash damage. It makes for a great opportunity to repair any floorboard damage while at it.
Regardless of all that, the floor shifted transmission and 4 wheel hi/low can be used if you keep all the BII mechanical linkage; otherwise you will need the 4.0's column with tree column shifting for the transmission and all the electric shift mumbo-jumbo for the transfer case.
NOTE
1- Incorporating the Explorer column will go better with the 4.0 dash and is moderately challenging. The 4.0l column is shaped different where it penetrates the firewall and the dash is hung from several different locations.
2- one bonus to using all Explorer is it will be at least 4 years newer than the BII's.
3- Another consideration is the gearing. Depending on your plans a 2.9l running 33" rubber at highway speeds likes 4:10 gears while a 4.0l running 33" rubber at highway speed prefers 3:73.
4- I recommend using at least the 4.0l exhaust with minimal alteration
5- the Explorer axles require the Explorer flanges, which are simple to swap over. Noting again that the rear drive line will need to be cut down a little.
6- the fuel system is another issue as the 4.0l using all hard lines with different fittings. There are plenty of choices here. Because I was in a hurry, I used the complete Explorer fuel system with the BII rear 23 gallon tank needing only to lengthen the 2 fuel lines about 2 feet. The fuel pump is another decision, again, I was in a bit of a rush so I just popped the 4.0l.fuel sender into the tank to get on the road. This problem that creates is that the angles of the two sender units are different: a BII sender will reach the bottom of the tank but need different fittings, the Exp fuel sender will only get you approximately 18-19 gls of fuel, as it is not angled correctly to empty the tank.
7- the D35/8.8" will move your wheels out at least ½" on each side, a good thing for improved BII stability
Any questions feel free to ask in your thread or PM; I have many pics of each stage except the axles which I did years prior to incorporating a 94 Explorer into my 87 BII.
Gaz, one note is the BII is 4x2 so it should have the dummy T case and just I beams up front but being a BII the D35 will bolt right in.
You don't "have" to use the Explorer dash, there's all sorts of 4.0L swap posts and stuff everywhere about isolating the engine side, I mean either way works...
You will need the axle pivot bracket for the passenger beam from a 4x4 Ranger or Bronco II, or a lift kit with new brackets (not relocating plates!) from a 4x4 Bronco II or Ranger in the 83-92 vintage to mount the D-35 because that bracket is different for the 2wd. The Explorer rear axle will need the spring perches re-welded and shock tabs added as noted, but the 8.8” is a good axle and IMHO is worth swapping.
Thanks for all the great detailed info! Lots to consider but glad to know the explorer parts will fit in the B2 with some modifications.
Another question I have deals with exhaust. My state law doesn’t require catalytic converters on vehicle as old as the B2. If I remove guts from converter or put in new pipe but leave O2 sensor, will it cause running problems? Don’t really care if it throws a code but not sure how or if ecm would try to compensate for converter not being there and cause engine running issues.
It is against Federal law to remove or gut a cat and TRS does not condone doing so.
IF you believe your cat is not doing its job, I highly suggest replacing it. It is possible to adapt to be able to use a universal aftermarket cat.
Contrary to popular belief, unless a cat is plugged, it’s not harmful to performance. That myth was brought about by the early catalytic converters having issues, especially with leaded gas.
@Joneskvn
The simple solution is to use the complete Explorer exhaust, it will require very little adjustment to fit your Bronco.
I one hundred percent recommend paying $80 plus shipping for either a high flow cat or the correct size cat for a 4.0l exhaust and another $76 for two new O² sensors (the 4.0l uses a left and right bank O² sensor); both of these components will lend to the highest fuel economy from your electronic fuel injected (EFI) PCM controlled powerplant.
Yeah, everyone hates cats but unless the engine has been ran with a misfire (IE stock plugs and wires for 150k miles) melting the cat they are not restrictive, at least at stock rpm levels... power wise you're in the 1% or less range unless plugged... making custom exhaust after the cats shouldn't be a huge deal...
Wouldn't the Explorer pivot brackets work? I didn't remember the pivot brackets being different on 4x2 BII's but I haven't paid 100% attention to that... but I could have sworn Explorer and Ranger/BII pivot brackets being the same as Explorer in the TTB years...
Maybe on the Explorer pivot? I thought about that but I don’t know for sure if they are compatible.
I know for a fact that the 89 2wd Bronco that I have the only non-4x4 part it had for the front suspension was the passenger side axle pivot. That’s the only thing that had to change other than swapping the dummy t-case for a real one. The coil buckets were actually stamped RNGR 4x4, BII 4x4/4x2
@jonesklj
NOTE
8-exercise caution when replacing 4.0l OHV starters, they are different for manual and automatic. The starter dust shield thingy spacer-jamma is another issue; use the 4.0l's, if possible.
The Explorer front axle brackets do fit the BII frame. I believe it's only the one bracket for the passengerside axle that needs swapped when converting a 2WD to 4x4.
92 Explorer (Federal emissions) only had the one O2 sensor. That's the setup I'm using. My y-pipe is still for an 88 Ranger with 2.9. Technically my harness is from a 91 but the only difference is a Barometric pressure sensor that the 92 computer couldn't care less about. (I've driven it with and without it. No difference at all.)
92 Explorer (Federal emissions) only had the one O2 sensor. That's the setup I'm using. My y-pipe is still for an 88 Ranger with 2.9. Technically my harness if from a 91 but the only difference is a Barometric pressure sensor that the 92 computer couldn't care less about. (I've driven it with and without it. No difference at all.)
92 Explorer didn’t use a barometric pressure sensor but 91 did
That's what I said... :dunno:
