Trying to solve this for a year now
Paisano
5+ Year Member
Phoenix, AZ
1992 Ford Ranger XLT with 2.9 V6
The problem is pulsating and 'washboard dirt road' vibration when I press the brake pedal. I have tried everything.
These are the areas I have checked more than once:
front brake overhaul done 2 years ago. I do all my own work and troubleshooting at home.
inspected rear drum brakes
inspected front disc brakes including bearings and dial gauge on rotors
inspected tires with rotation included
inspected steering linkage and steering shaft
inspected front suspension
pedals and steering wheel test for motor mounts......normal result
pedal tests for brake booster and master cylinder......normal result
bled brake lines
removed rear anti-lock brake valve and bypassed with new brake line
disc brake caliper replaced after it hit concrete floor hard.
Notable observations:
Earlier this year emissions testing station runs up engine with rear wheel on that roller treadmill thing.....and front wheels stationary
No 'washboard road' vibration
I run up engine with rear wheels on jackstands.........no pedal pulsating......no pedal vibration
This evening 5/26.......drove truck in drive and reverse in large empty parking lot
pedal pulsating and washboard road vibration felt in either direction
front driver side wheel checked again May 24
spindle axle stub has maybe 1/16 inch gap behind snap ring, where thrust washer and/or spacer should be.
I already have Spicer washer kit
I'm thinking front brake overhaul in very near future. What do you all think?
It seems you've isolated it to the front. You have 4x4 or 2wd?
What brand did you go for brakes? I went with napa brand a few years back, and the rotors were warped within a month of driving, and pads almost were gouging the rotors at 3 months. I warrantied them and same thing happened exept, they did gouge the rotors on my way to oreilys for some pads. Could also be bushings, steering, wheel bearings. Im sure the actual nerds will be able to help more.
  • Like
Reactions: gaz
I have electronic 4WD. But it has been disabled for years
I get a discount from my employer, I have BrakeBest rotors and pads. And part number A37 bearings
I get the generic brands
I don't see any unusual marks or wear patterns on the rotors, But it could still be excessive runout?
if it only happens when your foot is on the brakes, and not under easy acceleration too that eliminates everything except the braking system... rotors, hubs, bent rim those will all have harmonics and happen at 20,45,and 70 or somethin the like. so the number one suspicion on my mind if you are half competent and can go through the normal brake system and not find it is the primitive RABS (rear anti lock) system these gals have. these first gen RABS will pulse and that is my first suspicion.
old thread, gem for info: https://www.therangerstation.com/forums/threads/i-fixed-my-rabs.88318/
Did you have the pulsation before you did the brake job a couple of years ago? If so did it change, and if not did it start right then or a while later?
Just a friendly reminder
I completely removed RABS from the truck like it says in my original posting above. The pulsation/washboard dirt road vibration started about a year after I did the front brake overhaul. I never liked rear anti-lock braking system on my make/model.
Correction on my posting....I used a dial indicator to check rotor runout
When I'm driving at 10 mph, I can actually feel the brake pedal push up on my foot with a slow pulsation
If no objections or suggestions, I think I will proceed this way:
1. Check steering linkage and front suspension one more time.
(not sure of best way to do this.....other than raising front wheels off ground and wiggling parts to check for looseness)
2. Check bearings, washers, adjusting nuts on spindle axle stubs
If this doesn't reveal anything, I'll plan for front brake overhaul which I know how to do
Hmm... Brake booster?
Before you buy new rotors... take the ones you have in and have them resurfaced.
They will be able to tell you if they're not true... and if they're serviceable.
  • Like
Reactions: gaz
I'd recheck the rotors with the dial indicator.
Let me answer your questions.
Last time I checked the rotors with dial indicator, they were right up to max allowable runout or maybe more.
It's not worth resurfacing rotors. Even with my employee discount it costs too much.
Last weekend I was rotating driver side front rotor. It starts reasonably loose then tightens in the same spot when retested.
Not a huge difference. But unmistakably tighter.
I did a simple brake pedal test for the brake booster and it came back normal. It has been suggested that I disconnect vacuum from the brake booster and drive in a parking lot. Problem with this is the heavy pedal force required. Pushing pedal all the way down can damage
the master cylinder. (push rod thing extends too far). This happened to me once.
I have to replace a power steering gearbox, and I wonder if that would be a good opportunity to rule out steering linkage.
I'm not sure what you have for "allowable" rotor runout, I've seen .003" cause vibration.
As side from the runout, which I think is your problem. Residue on the brake rotor surface can cause a pulsation effect as well. Often times, the residue is some of the brake lining adhering to the rotor.
Since you metion feeling the pulsation in the pedal, I'm more inclined to go with the rotor runout being the problem rather than residue on the rotor. Some brands are more notorious for rotor warping than others. It could be the manufacturing process, the quality of materials used, among other things.
It could also be uneven torque on the lug nuts when installing the wheels causing the issue. I'm not familiar enough with the brake setup on your particular generation of Ranger to say if uneven torque can be a cause or not. If the setup depends on the lug nuts to clamp the wheel and the brake rotor to the hub, then it could be the cause. Some shops have resorted to using a cross iron to snug the wheel and then a torque wrench to final tighten the lug nuts so as to prevent bring backs.
If your setup is more like the RWD Rangers that the hub and the rotor are all one piece, then lug nut torque eveness is almost completely a nonissue. Never say never, but it's rare to uncommon enough to be heard of.
Unfortunately, new parts are not always good parts, and you could have just gotten a bad draw of the cards. Or, the brand you chose is a bad one with quality control problems.
  • Like
Reactions: gaz
