3 dead cylinders after overheat, before and after head swap
rangerlocal2
Forum Member
salisbury
NC - USA
Vehicle
Drive
Hello all, long time member here under my other highly similar username. Email got deactivated, so here we are......mods feel free to merge or contact me for new email.
Anywho, long story short, My ranger decided to blow the radiator cap off after a drive. I was able to get it off of the interstate and to a safe location but not until it had began to overheat after puking all the coolant out. After letting it cool and refilling, I was able to limp it home. Suspicions confirmed it was only running on three cylinders (2, 5, and 6 dead), but there was no mixing of coolant in the oil or pressure in the cooling system, so the bottom end is fine. Needless to say I knew the heads needed to come off, so I bit the bullet, even though the head gaskets seemed to be fine.
After getting the heads off, The valves were pitted and slightly warped beyond my comfort zone even with cutting and lapping, so I got reman heads and slapped them in. I did check the new heads for leak down and vacuum and all checked out. block was level and pistons and cylinders looked new. Rockers and pushrods were fine. All injectors checked out resistance wise and clicked. Surgical clean application of new gaskets of course.
Tldr: Fast forward to putting everything back together, the exact same three cylinders are dead, no change whatsoever. cat is glowing red so the injectors are working (unplugging injectors from dead cylinders gets rid of glow, no engine change), and I have spark in all six. No white blue or black smoke from the tailpipe, so the rings are fine. Swapped plugs and wires with no change. Unplugged the maf with no change. no cel or misfire codes, as before the head removal. Lifters all pumped identically and as expected, so no wiped cam.
I'm well experienced from years of wrenching on nearly everything under the sun, but this one has me damn perplexed. I thought maybe the coil could be sus, but I would expect a matching pair of cylinders to have issues if that was the case. Unless there's some hidden limp mode I'm not aware of, I'm totally stumped. Any and all suggestions welcomed.
Did you put a compression tester on it?
All 155+ psi.
And... if you want your old screen name back... we can have the administrator help with that.
Leakdown test?
Hmmm...
Strange indeed.
Did the injectors go back in the same holes as they were originally?
Indeed they did, exactly as they were before. New o rings and all.
Leakdown test was done on heads before installation. No light coming though the valve seat either, and all had a slight lap to verify seat to valve contact.
I should also probably clarify that before the overheat, The truck was running cherry. my coffee fueled exhaustion and lack of sleep. only after the overheat did the three dead cylinders show up, and they continued after head replacement.
So... with those compression numbers... they should lite up. Providing fuel and spark. You tried new wires and plugs...
Maybe try moving injectors and see if the issues follow the injectors.
Lawd, The thought of removing that intake again..... I did ohm them and click test, but when all else fails.. ... beats pulling the heads again. 😭. I can smell the fuel that's not burning in the exhaust so I imagine they're firing. But I'm nearly fresh I'm out of ideas.
Who knows what got sprayed with scalding hot coolant, possibly shorted, or cooked with heat. She did get steamy.
I know...
If you have a ST 125 spark tester... try testing spark on the bad cylinders first.
I'm just not sure where else to send you.
Buddy at this point I don't know where to send myself. 😂. I definitely will check spark again first. I know I have spark at the pack, and I did at the plugs as well. never seen arching to the block at the plug surface before, got excited at first, then cried when fixing it did nothing. 😭
Maybe a fresh day will show a new light. Might be a couple, but will post back when I have updates.
Your not like.. missing some pushrods or rocker arms or something on those dead cylinders are you? 😋 I mean.. probably unlikely but.. weirder things HAVE been forgotten to be reinstalled when someone's in a rush..
