2004 Camry wheel/brakes rattling/pulsating when it comes to a stop.
rogerranger2122
5+ Year Member
hopefully this is ok to post since I'm a member for my Ford ranger but
2004 camry w 120k miles.
This has been happening for a couple years. At first it rarely happened and was much less alarming and basically only happened when coming to a stop while turning left (pulling into the driveway was when it usually happened, but I test rode it for a while turning and trying to find the sweet spot to make it happen but it happened so rarely - I wanted the mechanic drive it and show how to make it happen but it was so rare at first. It's my dad's car, he though it was the front axle gear that goes into the transmission. I brought it to the mechanic was supposed to open up that axle and check but he just said 'the axle looks brand new I don't think it's that'.
Fast forward to now it happens every time right before coming to a stop, a rattling jittering almost grinding sound, break pedal vibrates, seems to be the problem is the front driver side wheel.
Brake fluid level is good, nothing leaking, I changed the rotors and pads a couple years ago they should be fine the car isn't used much, I also inspected them about a year ago before I brought it to the mechanic and they were fine.
I'm thinking it has something to do with the ABS. The ABS light came on but my dad said it does that when it hasn't been driven for a while but IDK what he means by that and I'm guessing the ABS module is faulty by the way it pulsates, it seems to vibrate in a perfect pulse as if it's the ABS. It's strange that it only happens right when about to stopm I don't know why ABS would kick in only then, I can be driving fast and hit the brakes and it doesn't have a problem. I could if suggested drive it fast and stomp on the brakes to make the ABS kick in and see what happens but rather not.
Recently I discovered opposite of what I was hoping: I idled up a hill so the car wouldn't just idle along and never stop. I was hoping nothing would happen and therefore it have something to do with the brakes/ABS but when idling uphill until the car is about to stop without hitting the brakes, I can feel a very slight pulsating, if I then hit the brakes it does the alarming rattling pulse. When idling up the hill until it's about to stop, without hitting the brakes, I hear a slight electronic beep as if it's the ABS module or something electronic, it's not like a diagnostic beep it just seems for whatever reason the part has a beep sound to it. Since it only happens right at low rpm (but not when taking off from a stop) I'm guessing maybe it also has something to do with the Idle air control electronics or something is so faulty that it's kicking in the ABS only when coming to a stop. Also when pulling away from a stop with the AC on (AC works good) it made a slightly alarming humm and dragging feeling but the AC hadn't been ran in a year and it seems to have gone away.
Straight from Google
Searched : 2004 camry, brakes tick and slight "beep" when stopping
Hope this Helps
A 2004 Camry with ticking and a "beep" when stopping likely indicates worn brake pads with exposed wear-sensor tabs, or, if accompanied by a brake warning light, a potential ABS/hydraulic issue. The ticking is likely loose pads/hardware, while the beeping indicates a sensor-activated alert.
Key Causes for 2004 Camry Brake Issues:
  • Ticking Sound: Frequently caused by brake pads that are loose in the caliper or missing hardware (shims), allowing them to shift.
    • Low Brake Fluid: The most common cause of a warning beep, indicating pads are worn down or there is a leak.
    • Brake Pad Wear Sensors: A metal tab scraping the rotor (causing a beep/squeal).
    • ABS/TRC System Fault: The 2004 Camry might produce an alarm sound if the ABS actuator or sensors detect a fault.
My daughter's '02 Explorer Sport had similar issue, because the sensor for the ABS had reduced magnetism and was no longer picking up when at very slow speeds.
A new sensor and all is good
I had an expedition do that too. Eventually it got bad enough it would do it at all speeds and not really stop.
I just unplugged the sensor i hate ABS anyways
ABS sensor sounds reasonable to me... if you were close I'd give you one, the wife has an '04 Camry and I have an '03 parts car to steal the engine out of (hers drinks oil but somehow runs like a top? I'll get to it one of these years...).
Oddly enough I need to change the starter in hers this weekend, it's on it's way out at a mere 255k but they're apparently the same starter on all engines somehow...
YOU SOLVED IT! thanks you guys are the best. I disconnected the ABS sensor and no more rattling. I'll try cleaning the OEM sensor but also order to have on hand an $18 aftermarket one with free returns.
Why it got worse and worse idk but the brakes work fine now. I saw a video where he jacks the camry up, takes the wheel and sensor off and the grooved sprocket that communicates with the sensor he turns the wheel to inspect those grooves aren't damaged so maybe some rust etc got in there and made those worse and worse is why the rattling got worse over the past couple years? IDK but hopefully a new sensor and it's fine or just disconnect both sides so the other doesn't kick in and potentially turn the car if ABS were ever needed.
Wheel bearings going out throws out the alignment of the sensor to the reluctor wheel, so it's either the sensor or the wheel bearings.
I was actually thinking wheel bearings, too, especially when @rogerranger2122 said that it was resistive to movement at first. The beep could be brake drag from a worn hub. The sensor seems to be a symptom.
I'd jack up the car and wiggle the wheel in and out in both north/south and east/west directions, maybe even take the wheel off and check the hub for grease trails. If none exist, drive the car for 15-20 minutes and then feel the lugs. If they're hot, bingo. If they're warm, pull the wheel off and sniff for hot metal/grease. Be careful if you go to touch the hub. Maybe pour some water on it and see if it steams.
Those cars are stupid light (the rear tires don't "look" flat until about 5psi, wife always seems to find nails with the rear passenger tire) and unit bearings up front are likely under low load, I doubt you would be able to tell from temperature... but yes I agree otherwise, the one I currently have the radiator out of in the shop driveway has twice that many miles and seems to be fine in the brake department...
I moved this to the other vehicle section. It seems the others have pretty well covered this. The only thing I can offer is that a lot of times, these vehicles use sealed ball bearing units and they must be pressed in to the knuckle with a press, not hammered in. Hammering will damage the bearing, whike the slow, even push of a press will not. Make sure you claify to a shop that they be installed with a press, preffereably after the bearings have been sitting in the freezer over night.
