Click no start battery cables start smoking
purple94
Forum Member
💻 TRS Socials
minneapolis MN
MN - USA
Other
1969 Mustang Coupe 302
Vehicle
Drive
been having intermittent click no start for a while, replaced starter a while ago been good for 3 weeks, click no start again today, and now the battery cables started smoking like crazy- positive touching ground somewhere? A short? Where do I start
Replace cables- they may be corroded and unable to pass current. To check, you can unhook the cable and use a known good jumper cable in its place. If that works you know it’s the cables.
Yeah, it’s possible the starter has failed (new parts aren’t what they used to be for quality). But once you let the smoke out of the wires, it’s time for new wires. Check along them for anywhere they may have rubbed and shorted when you replace them. I’d replace both positive and negative wires, make sure you clean the areas they connect for good contact and use dielectric grease or No-alox (hardware store electric section) to keep corrosion at bay. Personally I make new cables out of 4 gauge welding cable.
Bad starter isn’t going to smoke out my cables though is it? Just trying to rule out starter issues as it went from a click no start to an immediate start as soon as I replaced the starter
It’s probably age that got your cables , plus I’d like wager a new starter would start an bit easier than your old one.
If a bad starter failed with a short to ground or straight froze up, yes.
Bad wiring will also smoke wires. I’d replace the wires and get the starter tested.
any tips on replacing wires, were supposed to get 22" of snow tommorow and id like to be done by then lol.
I’ve done it by just figuring out what end I needed for the starter or frame or wherever the wire was going, crimp it on, and fish it down to where it needed to be, cut the length and crimp the top end. That’s the sloppy method. Takes a little more time, but I’ve also pulled the harness for the starter and grounds, tore it apart, put my new wire in the harness and put it back in, but it makes a much neater end product. I also mess with a fair bit of electrical so it’s just another day for me.
