I bet there's no chance to get people to stop calling Rangers by "Generation" is there...
scotts90ranger
25+ Year Member
Dayton
OR - USA
Drive
Too many opinions on this but calling them by generation is pointless as people will be looking for oddball things which never helps by using "generation". Some people want to call '83-92 first gen but go and order a fender or hood and have year ranges, need a dash or wiring help? Even dumber in year range since some early wiring was kept through '89 but other parts of it were changed for '89 then again in '90, instrument cluster pinout changed in mid '92
I still call my '90 second gen at times but I know most of the dumb that happened around then, for the most part I'll just refer to the year range... Everyone on the book of faces seems to go toward the wiki version of generation but myself I'm just trying to wean myself off of using that term for these random assemblies of ranger related pieces :)
I think this is why most dealership parts counters won't even talk to you anymore without a VIN... which I find highly annoying in itself. In town here Ford will ask and then grumble if you refuse to give it but they'll still make a half hearted effort. Hyundai has turned me away twice because I didn't have a VIN with me and they refused to even look up a part.
It is EXTREMELY easy to get burned freestyling ordering parts without a VIN.
Most walk in's don't even really know what they are looking for which does nothing to make it any more pleasant to do.
A busy dealer could easily look at it is as a waste of time at best. I would do it to test the waters for availability, if some plausible options were available I would suggest they either get a VIN or a part number so I can double check and make sure it is the right one.
Regular customer's have their VIN's saved in the system...
This is my generation
This is my generation, baby
Why don't you all f-fade away? (Talkin' 'bout my generation)
And don't try dig what we all s-s-say (talkin' 'bout my generation)
I'm not trying to cause a big s-s-sensation (talkin' 'bout my generation)
I'm just talkin' 'bout my g-g-generation (talkin' 'bout my generation)
I actually feel your pain; there's a lot overlap of this or that, middle of model year detail changes, cousins marrying cousins, and other weird stuff going on with the Ranger.
I try to just stick with the model year where I can, but there are still some things in conversation that are better addressed as "generation".
Even model year can vary.
For example an early '85 2.8 has the thermostat in the lower rad hose, later has it in the intake. Different housings, different hoses, different gaskets, different t-stats.
That is why dealers want to use the VIN, they can't just send the wrong parts back to their PDC like O'Reilly's can. They are stuck with them until some other sucker comes in looking for the misordered part. With something over 10-15 years old... there is a good chance that will never happen.
Then a company policy gets put in place you can't order anything with a VIN...
It’s better than “OBS”… now the Facebook experts call everything older than the current body style of any make OBS. Nobody knows what anyone else is talking about.
Sure sounds like cousins marrying cousins to me. :)
One of my cars had completely different parts used all over the vehicle throughout the production run. You should see the Haynes manual - there's 2 or 3 sections for each section. By different parts, I mean things that don't even fit in the same mounting holes, same trim level, same everything else. They just grabbed whatever was nearby I guess. No way to know what parts you have without having them in your hands, VIN or not.
Yeah, it's French, but don't judge, they sold 6 million of them :ROFLMAO:
I just find it funny, there was a facebook post about what ranger is best and someone just said "second generation" and I did what would have made RonD upset and said something about there's two opinions on second generation, the wikipedia description and the right one or something and sure enough they were talking about '93-97 which should honestly be split in '95 as well...
Not something I take serious, just too confusing
I thought I knew what OBS meant but then they change what it means all willy nilly like and yeah, too confusing...
Personally, I consider the 95 change to be a “facelift” because that’s closer to the truth than all those who claim that the 89 change was a Gen 1 “facelift”…
Really everything is a little muddled. The 98-00 and 01-03 have a different front clip. The fenders and core support are the same, but the rest changed. Then 04-11 are similar to the 01-03, but the turn signal plugs changed.
I agree, it's a complete mess! :)
It's kinda amazing that so much random stuff is interchangeable when so much changed, just don't try to do the one things you thought would be easy, that's going to be complicated...
Then some jerk like me comes along and muddies things more since my green 00 has an 01 grill and an aftermarket 04-11 set of lights… plus the 00 Explorer drivetrain…
Or my 89 Bronco II Choptop that started life as a 2wd with a 2.9 and now has a 91-ish Ranger 4.0 and a cobbled together 5” suspension lift…
The big ball buster '94 to '95 was OBD1 to OBD2 change, the dash design change, and the first rudimentary appearance of a body control module.. Not much, you'd think, unless wiring is involved.
The 95's also suffer from the "only that year" on some parts.
That's just part of what it takes to love these old trucks. Yeah, there's all of annoying changes that came along, but the fact is, these are just damn good old small trucks. No matter what year model.
Fun to drive, easy to fix, dependable. Honest. They simply are, what they are.
I bought my first one in '85. They're what I still drive (my '84, my '90 B2, and to my two '94 Explorers).
I have no desire to drive anything else.
"It's what works for me". Of course. "YMMV".
I have nothing against the newer ones: I think that they're every much in the same "nice truck" category as the old ones, but us old dinosaurs will be dinosaurs . . . . .
