2 quick questions
Dav
5+ Year Member
riverview, fl
none but it is a convertible
stock
How is the wire to the driver's side of the oil pan disconnect? Unscrew? pull 'til it gives? hidden clip?
Is there a trick to getting the fuel lines disconnected? One side at the pressure regulator came off easily with the funky X tool, the other will not budge.
TIA
Posted last night. This morning the fuel line separated on the first try. Go figure!
The oil level sensor is held in by a wire clip. It is in the groove on the nut that looks welded on the side of the oil pan. I had to take apart the sensor from the parts motor to find this out. Two small screwdrivers worked to pry the clip out.
Very well,n glad you got 'er figure out.
