Unable to find RCM via Forscan, tracing airbag codes.
bhgl
Forum Member
Northern Ontario, Canada
Howdy folks!
I've been working on my truck to restore airbag functionality after purchasing it knowing it was in an airbag deployed accident previously.
03 Mazda B3000, STD Cab, Auto, 3.0 V6.
After replacing the RCM (restraint control module), passenger and driver's airbags, I've been going through the codes flashed by the now working dash light to figure out what needs to be addressed next, however the entire time I've been unable to pull codes from the RCM via Forscan. I should not that the RCM was not appearing previously either. I've cleared 3 codes from the airbag light, one being a connection issue with the RCM, which has now been resolved so I know the car is able to at least find the module internally, and I'm onto code 4-6, the driver (and probably also passenger) seat belt pre-tensioner.
My main issue is I'm kind of getting sick of fixing them one at a time, with various trips to find parts, bulbs, and junkyard pulls and would REALLY love to be able to see most/all the codes at once if possible. And at the end of the list of codes, I'd like to run the RCM test to get an idea if the system is even working at all instead of doing real world testing (crashing it).
Alas, Forscan can't detect the RCM, I've tried clearing codes from the RCM, and running the tests but it's a non-starter since it can't be found.
When I've got time hopefully this evening I will post some pictures of what ForScan is displaying for reference, but any help is greatly appreciated.
Thanks as always!
This may be a stupid question but did you get the subscription? There are things you can see and change only with a subscription.
If I remember correctly... it could also be your cheap adaptor. Those things are not all created equal...
I did the free extended license activation, from what I've seen it should be able to find the RCM without a paid subscription.
I made sure to buy a recommended one that was specifically for ForScan, it's the Vgate VLinker TP, which I know others have used successfully with ForScan.
When it comes to RCM module issues specifically, I don't know if others have used the adaptor work on RCM issues.
We'll need to wait for someone who has more experience with the software then. @lil_Blue_Ford might be able to help. I'm not sure who else has used it more but they are on here.
When I was looking... this is the unit that was recommended. I don't know if the adaptor is your problem or not... but I believe it could be. Try it on a different ford and see if it connects.
OBDLink MX+ OBD2 Bluetooth Scanner for iPhone, Android, and Windows https://www.amazon.com/dp/B07JFRFJG6?tag=959media-20
Howdy folks!
Thanks as always!
Hey there! Sorry old thread, but this is this is the only one I have stumbled across with a similar problem to me where FORScan simply doesn’t want to recognize let alone show codes related to the SRS…
Were you able to resolve it?
Thanks for replying if you even see this haha.
the one with the cord and switch works on edge escape and explorer.
the regular wireless dongles can be finnicky more often than the corded one. but the corded ones are fragile......cheap...but fragile.
if you live on a bumpy arse dirt road ...especially salty ones...cleaning and repluggin the connectors has been a thing. b2296 was that code
I actually bought the one FORScan recommended, the OBDLink Ex.
Connects fine and I get codes from the GEM, PCM, and ABS, but nothing from a module that would be related to the airbag.
The airbag light stays on solid, never blinks or anything.
I’m starting to think I have a ground issue somewhere, or the airbag module itself is just toast.
Going to track it down to see if it’s getting power.
by definition it is not connecting fine if it is not connecting with the srs.
the high speed, low speed, and medium speed, lin/lan/can and whatever the fawk else thay have come up with proprietary systems dont always work well with the non switched wireless dongles, though the one linked by gump is supposed to work with everything to date.
so this is appears likely either a bad module or the connection to the module is loose or corrupted somehow situation. i dont know the specific location off hand for this but starting with the smart box connections and cleaning those up and inspection for corrosion or contact burning isnt too bad.
