1990 Ford ranger 2.9 shifting issues
Terbo
ASE Certified Tech
Bartlesville
OK - USA
Other
07 Chevy 1500
Vehicle
Drive
I tried. I actually tried. If I fail then I will try again.
Hey everyone,
I just joined this group so sorry if this is the wrong area for this post.
I have been working on a 1990 Ranger 2.9L V6 for the past 6 months at my local tech school. I just got the motor back in a few weeks back and today i finally got it started and running well enough to drive and when i took it for a rip it wouldn't shift out of 1st, i could place it in second but it wouldn't shift out of first on its own.
I did not rebuild it either, i took it apart all the way, top and bottom end, to the block and basically put new lifters and new gaskets on everything. I didnt have the money to rebuild it right, or replace components like pistons, crank bearings, and the like. I did get new valve seals and the lifters because the old ones fell out when i took the heads off.
I was wondering if anyone had any advice or thoughts on the whole deal and specifically the shifting problem.
The A4LD is vacuum shifted.
There should be a vacuum line that runs from the trans up to the vacuum tree...i would start with that.
Thank you sir that was exactly the issue, line had come undone on the tranny. It won't shift into 5th now.
Its only a 4sp trans :)
Glad i could help though
Oh hahaha i didn't realize that. : )
So it must have been slipping from 3rd to 4th then. lol thanks for the correction sir.
