High Tach reading
Hawkeye
5+ Year Member
Florida
On startup my Tach goes to roughly 2500 rpm. Not the actual rpm of the motor. The rpm will go higher, but not any lower until I shutoff the engine. I have not looked at anything yet.
Any suggestions?
Sorry I misunderstood your question and deleted my first post.
You're saying the tach jumps right to 2500 and never goes lower? The gages have posts that push into metal clips which make a connection to the flexible circuit board on the back of the cluster. They can loosen up and cause weird stuff to happen.
This will sound a little caveman, but a few taps on the dash could make the needle move if I they're loose. My tach was erratic and tapping on the dash would make it move.
Any suggestions?
Sorry, my post was a little confusing. The truck runs fine. It's just the tach goes to 2500 on startup and won't go lower until shutoff. I tried tapping on the dash panel/ gauge with no fluctuation. One thing I read on a Google search, mentioned the ignition coil or voltage regulator. Is that a possibility? Or is it most likely something in the instrument panel?
