tranny swap from 88 BII to 92 BII
ncd76
10+ Year Member
tranny swap from 88 BII to 90 BII
I would like to swap my 5 speed tranny from 88 BII into a 90 BII. Is this swap possible? The 90 tranny is 1 piece and the 88 tranny is 2 piece. also the lines running to the clutch are different.
what tranny is in the newer BII and what tranny are you putting in to it? but yes you the swap will work.
Since '90 was the last year for a Bronco II, are you sure it is a Bronco II it is going into?
In the '88 Bronco II's the transmissions are the same length since in '88 they got the FM-146 in place of the FM-145.
nope, can not be done...seeings as how there is no such thing as a 92 bronco ii
The slave cylinder line is different from 90 to all earlier years of bronco II so I guess my real question is as far as the slave cylinder line goes is it as simple as cut and past?
