Crank no start
horse cave
CT-USA
Other
5.9
Vehicle
Drive
I have a 1991 2.9l 5spd it died when it got warm for a while and now it won’t start at all. so i cleaned grounds replaced tfi module, cleaned IAC, checked for vacuum leaks, and replaced fuel filter. I also ran injector cleaner though it incase it was a dirty injector. It holds 40psi fuel pressure and has spark and compression. I’m not familiar with these motors i’ve read to replace crank sensor i’ve also read they don’t have one. What else should i check? TIA
2.9 no crank sensor. it is tfi with a distributor. assuming you didnt cause an issue with the module replacement.
do the injectors have power?
