- Nov 13, 2018
- Canaan
- State - Country
- NH - USA
- Vehicle
- Ford Ranger
- Drive
- 2WD
- Total Drop
- 3"
- Tire Size
- 235/55R16
- My credo
- If you don't have time to do it right will you have time to do it over?
Ford didn't "rebuild" it, the Ford dealer did. And for an oil consumption concern they would have probably replaced the rings, honed the cylinders, and maybe replaced the valve seals- that's far from a rebuild.The stock 460 truck cam would be considered an RV cam by the aftermarket. They had a slightly lumpy idle because they were calibrated lean, a cam that would make a lumpy idle would reduce low RPM torque. From my experience, the "higher ups" never know the details of how things work and never let the boring truth get in the way of a good story.The 89 had an oil consumption problem from day one. At 30k, Ford took the truck back and said they rebuilt the engine. Dad also knew a higher up in Ford back then and he stated that Ford was putting RV cams in a couple years of 460 motors for the cab-n-chassis trucks, which is what that was. I don’t know, it always had a mildly lumpy idle and it would get going in 3rd from a stop if you were empty (dump truck). The 94 was bought as the identical truck, just newer. Same everything. It did not run nearly the same.
The oil consumption problem with the 460 is valve guide related.
