2.3L ('02-'11) UPDATE: Now I need used front seats, fuel tank, skid plate [How to evaluate '08 4 cyl if can't test drive, get stored codes, or do KOEO/KOER tests?]
knuckledragger
Forum Member
Firefighter
Oaktown
CA - USA
Vehicle
Drive
Update, 1/23/26 on how it turned out:
TL;DR: Thumbs up. Now I need to find used front seats, used fuel tank, and used skid plate
Longer version: First off, thanks everybody for your help and insight. Fortunate turn of events, a friend of our extended family, who's a longtime dealer mechanic and is nowadays a full-time diagnostics specialist, very kindly offered come over on his day off and put his experience and hi-tech equipment to work. His pro dealer-type gizmos could do a bunch of testing and analysis well beyond what me and my tools were capable of, and he knew what live data he needed to look closer at and how to put the motor and trans through some paces so he could view and analyze it under various conditions, plus he did a great visual and hands-on inspection. All said and done, he did come up with a list of important problems and symptoms that will need to be dealt with (most of which I hadn't picked up on) and after we hashed out where to go with solutions and fixes he said all things considered, the newly acquired mechanical/functional/aesthetic downsides shouldn't be a dealbreaker. So on to the (first) next thing: I need to find used 60/40 front seats, a used fuel tank, and a used skid plate. Would prefer to get 'em from a local source, so if you know of any sources in or near SF Bay Area, please clue me in. (fwiw I've already looked at the "Pick N' Pull" brand yards in Oakland, Richmond and Newark, no dice on Seats, fuel tank, or skid plate. Thanks again y'all!
Hi and thanks in advance for your help.
Total newbie here and this is my first Ranger so feel free to go easy on me. Been driving myself nuts the past few days trying to figure this out by endless internet searching and reading. No dice. I bow to your superior knowledge and humbly ask y'all to educate me.
VEHICLE:
2008 Ranger, 4 cyl., automatic trans
NEED:
I need a rock-solid way to evaluate the condition of motor and transmission without being able to test drive, get stored codes, or run any KOEO or KOER tests.
URGENCY:
High. Being pressured by insurance company to make very quick decision re whether or not we'll buy back the truck they've declared a total loss. (If we keep it we'll have to pay the insurance company whatever the truck's worth as salvage). Can't afford to end up with a salvage truck that needs a bunch of motor or transmission work.
THE BIG QUESTION:
Given that there are no stored codes and it's totally impossible to do a test drive, and given that, unless someone knows some cool trick(s), it's totally impossible to run KOEO and KOER tests (see below if reasons why are important to you)...
Is there a way, using a good off-the-shelf OBD2 scanner, to run some other tests that add up to being as good as, if not even better than, the KOEO and KOER tests as a way to size up the motor and transmission?
Like maybe using a bidirectional scanner to tell the truck to run whatever tests?
(but I'm not even sure if the 2008 ranger can do anything bidirectional, couldn't figure that out on the internet)
Or maybe by capturing the "right" or "best" real-time data?
Or by doing something else I'm currently unaware of?
MORE CONTEXT:
* Motor starts and runs
* Engine sounds and looks generally okay
* Everything under the truck looks intact and okay
* Transmission condition unknown, haven't tried it yet
* Keep alive memory was wiped (battery was removed), so no stored codes and can't run KOEO and KOER tests (DTC P1000 aka "OBD Systems Readiness Test Not Complete")
* Even if trans is ok, truck isn't drivable more than approx 20 feet either forward or reverse (making it impossible to do the drive cycle required before being allowed to run KOEO and KOER tests)
* Aside from the mechanical unknowns, damage is just cosmetic and we're not worried about being able to get that stuff fixed up
* If no big/expensive motor or trans work is needed, the truck is probably worth keeping (it's been well cared for and it's been good to us)
* I have a decent off-the-shelf scanner already and can get a better one if need be
* I have an okay basic set of mechanic tools and whatever tools I don't have, I can get
* I know a fair amount and have decent mechanical and technical skills - I was a teenage mutant motorhead and grownup junkyard dawg, but that was back in the caveman days when the machines were simpler and way less digital, and I swore it off a long time ago - nowadays I don't have the inclination or patience for good troubleshooting or wrenching. So even though we've had this truck for a good while, I've never done any of the work on it. So all things considered, getting into hands-on/wrenches-on/mulitmeters-on troubleshooting and diagnostics on this truck right now would be a big learning curve, and I don't have the time for that. And plus dammit I just plain don't like doing it anymore.
But, as we all know deep down inside, being a motorhead and junkyard dawg is like being a mafioso or a CIA agent: no matter what you think or do, and whatever you say to yourself or anyone else, you can never really quit the brotherhood. So I'm glad as hell y'all are here for me. I know that collectively you've got all the answers and knowledge and skills and talents and tricks we'll ever need. I know y'all can tell me exactly how to size this thing up proper so I'm not stuck with a dud.
Hit me with whatever you got, looking forward to hearing it. Ask questions, glad to answer. You rule.
Thanks again in advance.
KnuckleDragger
Why can't it go more than 20 feet?
Go old school and do a compression test and, or a leakdown test. Tho you did say it sounds fine but that will rule out mechanical problems you may not be aware of.
I can't help on the computer diagnostics...
Why do you think the engine and/or transmission condition may be any different than they were before whatever caused the total loss situation?
Thanks for thinking about it and the good ideas.
One big reason is need to keep on the good side of the law and it's currently not road-legal. And then there's the whole fuel tank situation, I won't bore you with the details of that. And a few other things that make it undriveable except for the 20 feet or so. Safe to say that without a fair amount of time, money, and work, that Ranger's not going anywhere without a tow truck.
Totally viable suggestions, thank you. I s'pose if I can't come up with a way to get highly relevant insight from OBD2 data it might just come down to stuff like compression and leakdown tests (which btw are two of my go-to party tricks from back in the caveman days). But I'd sure like to get a more detailed and comprehensive picture like we can do now in the space age. And it'd sure be nice to find out now if getting the darn thing re-smogged would be an expensive and time-consuming proposition. I mean, a person can dream, right?
Brother! Excellent to meet you here! We might've met up or known some of the same people back in the caveman times, when folks like me were happy fixing the village truck with a stick and a stone. You got valuable skills man, irreplaceable. Keep going for it.
Oh, great question. Short & sweet, it was driven for a while by a very irresponsible, disrespectful, aggressive destructive person who quite possibly drove it as irresponsibly, disrespectfully, and aggressively destructively as they possibly could. No telling what the poor thing might've been put through during that time. So due diligence is required.
From my point of view, the thing doesn't make enough power to be significantly damaged by aggressive driving for a shortish while, so I would just buy it and move on. (Assuming they ask a reasonable amount for it.)
do you have workspace and time? replacing a tranny in a 2wd is easy.
are the fluids still OK?
I'm 2000 miles east of you in the rust belt. anything rust free is worth it here.
I have a 2005 with the 2.3, but a manual tranny. the first 250,000 miles were nothing but oil changes, and brakes.
these trucks are quite durable.
@rubydist I'm envious of your optimism! I definitely wish I could share the sunny outlook. Thanks for making me realize I misspoke: Where above I said "aggressive", I actually meant, and should've said, "destructive". I edited the above to make that change. And you know how it is - destructive people can make their destructive urges remarkably effective, especially when they really put their minds to it. Regrettably, knowing what I know about the situation, I can confirm that it's for sure a crapshoot. So sad to say, real due diligence is definitely required.
Workspace, only sorta. Time, no. Spare dough and general bandwidth, both also no.
No doubt. From a mechanical skill pov I could do it. From patience and "other irons in the fire" pov, I couldn't.
Fluids all look ok.
Oh heck yeah. I've driven and maintained some rattletrap rustbuckets (thankfully not for a long time now, don't miss it a bit)
Nice! The automatic trans is the only thing on the truck that I wasn't stoked about. Always said that when it came time for a new tranny went out we'd have it replaced with a manual (I've even heard rumor of a possible 6 speed manual).
Yes! It's just over 100k and was in really good shape across the board, the vision was always to keep it in nice shape and rolling on the OEM as long as possible and having time to build up a fund for replacement motor and trans sometime way down the road. Sadly, we haven't had enough time to build that fund up enough. Even if it turns out the current motor and trans are still good and we end up keeping it, once we get the other stuff that needs fixed taken care of, we'll be pretty tapped out for a while. lol guess you could say our surefire plan to become obscenely wealthy and take over the world is taking decades longer than we thought
my plan didn't work either :icon_thumby:
