help with ABS brake problems
that09ranger
Forum Member
💻 TRS Socials
conway
AR - USA
Vehicle
2 inch level
goodyear trailruner ATs 235/75r15 29inch diameter
i drive a 2009 ford ranger 2.3L rwd with front rotors and back drums, when i am driving and apply the brake sometimes my brakes will lock up amd slide and grind like my abs censor is kicking in,and my pedal shakes and vibrates. it will not happen every time but it happens often. especially while in reverse and while turning. i have had it looked at and adjusted but it still does it and my braking is slowly getting worse.
front or rear locking up?
one end locking up usually means the other end is not working properly.
it feels like the front is locking up
Find a dirt road and do a bunch of stops, if it acts up you'll be able to tell where the problem is. For example, if you have a leaky axle seal or sticking brake cable causing the rear brakes to grab, it would cause the ABS to activate. So would a loose front wheel bearing.
oh, my front pass bearing is blown
Event Coverage
TRS Merch
