New guy looking for help with a v8 swap
Farmer83
La Place
IL - USA
Other
Mustang
Vehicle
Drive
28x10.5
Hi, new guy here. My name is Jason, but I go by Farmer.
I picked up a 97 ranger extended cab 4.0 ohv 5spd this past summer. She runs ok for 220k but lacks power. I have always wanted to do a 302 swap & have been looking for a good solid truck like this for years, no rust at all but she has been used as a truck therefore she has a few minor dings in the bed rails ect.
Anyway, I have a fairly well built 306 with a c4 that I am planning to transplant by this coming spring. I'm looking for advice on headers & exhaust from there back. I have 1 5/8 fox body headers & a 2 1/2 h-pipe to work with. I also have a built 164 tooth c4 [large bell] that I need to find a 157 tooth bell for, along with a 50 oz imbalance 157 tooth flex plate. I have found a 3500 Stahl 26 spline converter that will work with the parts i'm looking for.
Any help/advice would be appreciated.
2wd the old school Shelby style Tri-Y's are hard to beat. They can be made to fit a 164t bellhousing but fit a 157t really nice.
After the headers will have to be custom. You could find a axleback kit and have a shop mesh the headers to the kit.
Thank you.
I'm going to need an 1 5/8 primary header minimum, has anyone used a shorty style header with any success? It's looking like the steering shaft & the passenger frame rail are the biggest problems.
The steering shaft is less of a problem than it looks. The frame on the passenger side is the issue. I am doing a similar swap this spring as well. Headers options are few. I'm learning towards trying tight tuck headers from Patriot with a flat primary collector.
Thanks for responding! I am more worried about the steering shaft room because I am in need of an 1 5/8 primary header, the frame can be cut back if needed to make room but I'm kinda stuck with the steering. I'm going to call Doug's Headers tomorrow to see what he thinks about a set I came across & if he thinks they will work I'll be back to let ya'll Know. Good luck with your build.
Event Coverage
TRS Merch
