Rear brake rubber lines
shaka.brah
10+ Year Member
Ok here's my issue. I am in the process of lifting the rear 3" but the rubber line is a little too short. I've seen the thread regarding the front lines (from the man himself) but I can't find anything on the rear lines. Has anyone done a mod of extending the rear brake lines ? Maybe something from a different model or piecing two shorter ones together ? Thanks in advance.
On jeeps they sell brackets to remount the bracket that holds the brake hose lower. Can you make something like that? And then just use the original hose. You will have to re-form the steel brake line a little bit.
I will definitely look into that. It's worth a shot.
1988 Bronco II for the rear line. I have about 5-6” of lift on my Choptop and the line is still plenty long.
When I lifted my '90 we did the dumbest thing we could and it worked great... my friend had an extra shock bushing tube thing and we just spaced down the hard line by that amount by taking off the drivers side bump stop that normally holds the line to the frame and lowering it by that ~2"... I haven't fixed it since it isn't broken...
