Greetings from Michigan!
Fraser Engine Co is their name, located in Fraser, Mi
After reading the reviews of that place, I sincerely hope your engine is bulletproof like they said it was. Engine failures seem prevalent, and warranties are not supported. Everything I've seen says they'll sell you an engine, but if anything goes wrong, they threaten to sue you instead of going through with the warranty. I don't mean to be alarmist, but that's quite shocking.
That is a little worrisome but me and my old man checked it thoroughly (he's a machinist) and everything seemed to be on the up and up. I know he stuffed a crate from them in his old f150 and that thing is still trucking.
But update!
Got her all in, everything is hooked up. Having some trouble with the camshaft sensor positioning, chiltons says 38 degrees, the other number I'm getting is 15 degrees so, that's where I'm at now. Also have to find the small inspection cover plate that gives you access to the flywheel bolts as I had to cut mine off. I'll grab some pics here in a minute.
This is good news. A bit of professional assistance goes a long way!
Got her all settled in, hooked up and running. Used most of the old hardware, plan on upgrading paycheck by paycheck 🤣
Only had two codes pop up, minor and I'm pretty sure it's a simple fix. Running great so far, original had a quarter million on her so, hopefully, here's to another quarter million.
